Well the Red light “check” continued while hooked up to battery.So I trashed the Odyssey charger. I bought a NOCO genius model G3500 charger from a Portland area battery store. Spoke with the owner and decided on his recommendation that the G 3500 is the best for my 680 Odyssey battery.. it can charge 6&12 V. Wet cell, gel cell , Enhanced flooded,Calcium batteries,AGM,Lithium ion. It charges at 14.8 volts 3.5 amps for Odyssey AGM batteries. Has a 12 V repair mode which is an advanced battery recovery mode for repairing and storing, old, idol, damaged, stratified or sulfated batteries. When I hooked up the charger to my battery it showed a 25% charge in it’s analyzing state prior to starting the charging mode. There are four status lights at 25%, 50%, 75%, and 100%, . I am very satisfied with this purchase and thought the $75 Price was right. I did call vans to ask about a charger and they indicated they do not sell a charger anymore. I would imagine if you were to Google the model number above you could read all about it I believe I did my homework well On this product. Hope it helps. He would be glad to answer your question at
drycelbatterynw@aol.com ask for Scott.
Ron in Oregon RV9A
