06-03-2018, 02:33 PM
Manifold restrictor plugged with carbon
After 500 hours on my Superior IO360, my manifold pressure gage (cylinder #3 port) quit responding to engine power settings. This is what I found:
Is this normal? I cleaned it with some MEK and safetywire. All is working normally again...
Engine is dual EI and fuel injected.
Don
06-03-2018, 06:15 PM
My 10-Friend found black goo in his line, it was near solid when cool, then as it warmed, the MAP would work ok. ~200 hrs. The goo is heavy ends from fuel, like pitch. It could easily harden with time.
Was your hose/line clear?
Bill
RV-7
Lord Kelvin:
06-03-2018, 06:25 PM
I imagine this could be bad for a electronic ignition engine with MAP for timing.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
06-04-2018, 01:11 PM
?. I had this as well with a line going to my map sensor for the
ignition. I moved the pick-up to the carburetor base, eliminating
the problem and gaining a much smoother signal in the process.
The engine actually seems to run a bit better (I think). Thanks,
Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & ServicesInfo@AntiSplatAero.com Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
06-09-2018, 04:37 PM
Originally Posted by PerfTech
…. I had this as well with a line going to my map sensor for the
Allan...
I did the same to avoid this problem. There is a lot of reversion in the intake port area and you should expect carbon build up there.
Larry
06-10-2018, 07:04 AM
Unfortunately, this is on a fuel injected engine, and there is no port that I'm aware of near the servo. It took 10 years for this to plug up and the MP readout is a luxury for me with a fixed pitch prop, so I might just have to live with periodic cleaning.
It does affect the spark advance on my electronic ignitions, but that just means they will operate at 0 degrees and shouldn't be a flight safety issue.
It just seemed odd that I would see this concrete-like build-up on the upstream side of the combustion chamber and I was worried that I had a sticking intake. The rebound theory seems to be more likely to me.
Thanks!
Don
