Scott,
I was concerned about the same situation as are you and also wanted perfect alignment of the elevators with each other--the counter weight alignment was secondary since out of sync elevators would create far more negative aerodynamic effect than one counter wt being up or down slightly relative to the HS . To deal with this I bought a couple of long pieces of angle and insured that they were true and straight. I clamped the angles across the elevator trailing edges (mine is a 9 and has non-tapering trailing edges--your 7 will require a slightly diff location) to get the elevators aligned. I double checked the elevator surfaces by using a smart level to insure that the two were the same . I then clamped the two together at the horns and double checked the alignment. THEN I drilled (or should I say redrilled--more on that later) the elevator horns. BTW, as you probably know, this can only be accomplished without the rudder in the way.
Reference the comment on "redrill"--the first time I drilled the horn I simply locked both counter wts in trail, eyeballed the elevator alignments and drilled the horns---only later to realize that the elevators were not perfectly aligned by using this procedure. Although this presented no safety issue, I could'nt stand it. I had the horn welded up and I redrilled using the above process. Others may think it a lot of work for little return---I get some satisfaction in knowing the rigging on my plane is as near to perfect as I am capable of attaining. Anyway, its your plane -- put the level of effort in that gives you a result with which you are comfortable.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
