Old 06-01-2018, 06:21 AM
dmat dmat is offline
Default 1/4-20x 1.65in Bolt for FAB to RSA5?
Hi all,
I have been trying to find a 1/4-20 x1.65inch grade 3 bolt as I needed to make a 1 inch spacer between the FAB and the servo and Mcmaster-Carr/Fastenal doesn't have it. Does anyone know where I could get this size?
I found a 3 incher which I could cut down but it doesn't have a drilled head for safety wire.
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
Old 06-01-2018, 08:24 AM
Would it be acceptable to use a bolt with lock washers in this area?
Old 06-01-2018, 08:56 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
This might do it. Under the old part number AN74A-16
https://www.bandbaircraftsupplies.co...mart&Itemid=73
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-01-2018, 09:34 AM
Thanks AZ. I will try them.
Old 06-01-2018, 10:12 AM
cajunwings cajunwings is offline
Default Bolts
You could drill the head yourself if you can?t find what you need.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 06-01-2018, 10:15 AM
I was thinking about doing the drilling but wasn't sure if grade 5 hardness will allow for it. Plus I would have to buy a jig (I think).
D
Old 06-01-2018, 12:43 PM
lr172 lr172 is offline
I would make my own. I had these exact bolts with lock washers loosen up on my 6, so would recommend safety wire here. I made my own prop bolts and was able to drill the heads of grade 8 bolts, that are much harder than a grade 5. I think a grade 3 would also work in this application as there is not much load, just a lot of vibration.
Use a cobalt 1/16" bit on a drill press and you should be able to get it done. Go slow and use oil. No jig necessary, just a spacer under the threaded part of the bolt to keep the head perpendicular to the drill bit. The bolt's flat will keep everything stable once you have the right sized spacer. Buy an extra bolt in case you break off a bit in the head, but that shouldn't happen with a grade 3 or 5.
Larry
Old 06-01-2018, 01:23 PM
rocketman1988 rocketman1988 is offline
Default Uh...
I think that an74 bolt is 1/4-28 not 1/4-20...
I used some Nordlock washers on my throttle body bolts...still thinking about drilling the heads though....
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 06-01-2018, 01:41 PM
az_gila's Avatar
Smile
AN74A is coarse thread... check the specs and the description in the link I posted...
Gil Alexander
Old 06-01-2018, 03:28 PM
Default Well I be darned
You know I was looking for those bolts and couldn?t find them. 1/4-20 they are...
Thanks!
Bob
RV-10
297 HP Barrett Hung
Wiring...
