Old 03-16-2007, 08:22 AM
Fearless's Avatar
Fearless Fearless is offline
Default Fuse Boxes - Who used them?
I know i am early in the build but I been thinking of what electrics components I need to incorporate into the plane. I'm reading the AeroConnection book and what Bob has to say about fuse boxes.
Other than Mike in Texas with his 9a who else is using the automotive fuse boxes instead of circuit breakers in their build?
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 03-16-2007, 08:31 AM
DGlaeser DGlaeser is offline
Default Using Fuses
I've building an all electric airplane and using fuseblocks per essentially the AeroElectric z-19 architecture.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 03-16-2007, 08:34 AM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Default Do a search in the forums to read the various threads...
There's been a lot of discussion about this. I don't think there's a wrong way, only a matter of personal preference. If you read the book you understand Bob's logic in going with the fuse blocks. I used the fuse blocks per Aero' Bob in my 7A and am happy with that decision. I'd do it again.
RV7A-QB, RV-10
Old 03-16-2007, 09:40 AM
Jekyll Jekyll is offline
Fuses.
Jekyll
7A
Old 03-16-2007, 09:44 AM
videobobk's Avatar
videobobk videobobk is offline
Default Fuses in mine
I went with fuses and am happy with it. The ten-fuse block drops down between your knees for service. Takes no panel space and saved a couple pounds.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 03-16-2007, 09:55 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
ATO fuses in both my aircraft. Lighter, cheaper, more reliable IMO.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 03-16-2007, 10:48 AM
Davepar's Avatar
Davepar Davepar is offline
Fuses here.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 03-16-2007, 10:54 AM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
Yep, fuses.
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
Old 03-16-2007, 11:35 AM
kentb's Avatar
kentb kentb is offline
Default FUSE BLOCKS (3)
20 - main power
10 - endurance buss
6 - hot buss
2 - circuit breakers (alt field, stdy alt field)
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 03-16-2007, 04:02 PM
dmeloche dmeloche is offline
I'm using fuses per Nuckols. Work great.
