Old 05-30-2018, 12:15 PM
Michael Burbidge Michael Burbidge is offline
Default Higher fuel pressure after transducer install
I have an O-320. I just installed a JPI engine monitor, with a floscan fuel flow transducer.
My fuel pressure before the install was 4.5 - 5 psi. After the install it is 7 psi. According to the Lycoming Operators manual 7 is still acceptable. But I'm just wondering if a fuel flow transducer can increase fuel pressure? I assume it adds some resistance to the circuit and so it makes some sense that fuel pressure would increase.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 05-30-2018, 05:59 PM
Michael, could be since the orifice in the transducer is about .180.
Tom
Ridgeland, SC
Old 05-30-2018, 07:35 PM
The difference could also be explained by differences in the sensors or the instruments they are attached to.
When I switched from analog gauges to digital in my RV-6, both my oil temperature and oil pressure readings dropped, even though nothing else changed.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
