Old 03-16-2007, 06:49 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default which dimple dies on tank stiffeners?
I am about to start my Proseal adventure and have a question. I plan to use the tank dies on the rib rivets, and put a bit of PS into the hole before each rivet.
What about the stiffeners? I was planning on backriveting them and would ideally pre-load them all into the skin dry, then putting a "wet" stiffener on from the inside. In this case, would I be better off with regular dimple dies since there probably won't be any Proseal in the dimple?
What did you experts do? Thanks,
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 03-16-2007, 07:04 AM
Sid Lambert Sid Lambert is offline
Default Does it matter?
I bought a set of dimple dies to do the tank and found there really isn't much difference in the amount of proseal left between the skins for each die.
My reasoning is that if you make a hole the size of a marble and you fill it with a marble you have the same free/open space as you would if you filled a the size of a BB with a BB. I also had concerns about the manufactured head on the rivet leaving open space under it when shot since the head is slightly recessed.
Just use whatever you think looks best.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
