Elevator trim indicator.
1. Center the trim indicator by moving your trim switch servo.
2. Then center the elevator trim by adjusting the elevator tab.
Aileron trim indicator.
2. Center the aileron trim so the arm on the bias spring is straight up and down.
Check both for trims full and correct movement.
It?s really quite simple!
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Aerotronics panel with Dual GRT Horizon WS, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level, Electric trim, Tosten 6 button Military Grips, FlightBox wired to WS, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
