Old 05-28-2018, 07:19 AM
Kupde Kupde is offline
Default First flight! and a question
First Flight
Saturday before the big Florida storm hit I was able to do a first flight. Everything went well with no big surprises. One question: my pitch trim works fine on the ground but in flight I found that at cruise that it wouldn?t move past neutral to allow me to trim it out completely. For some reason it showed power going to the trim as I pushed the switch but it wouldn?t move past neutral. Tried it again on the ground and it worked fine. I have a VPX system and I?ve input the positions with plenty of space on each end of travel so not sure hat it is? Any suggestions welcome.
Kevin
Old 05-28-2018, 09:22 AM
Congrats Kevin!!!!!!
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 05-28-2018, 10:00 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Congratulations
Originally Posted by Kupde View Post
First Flight
Kevin
Kevin, big congrats on the new fledgling
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-28-2018, 10:06 AM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
Congrats on your first flight!
The VPX might be slowing down your trim motor too much when your airspeed gets higher. I don't have a VPX, but I built a similar speed sensitive trim controller, and when you get it too slow it doesn't have enough power to overcome flight loads on the trim tabs and the trim motor will stall. Speed it back up a bit and it should be fine.
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 775 hrs
OnSpeed development team
Old 05-28-2018, 11:20 AM
rongawer rongawer is offline
It might be that the stops are configured in the VP-X different than the PFD (I?m assuming you have an EFIS).
The VPX software has a trim configuration tool. I recommend connecting a laptop to the VP-X and cycling the trim to see what the VP-X thinks is going on. It?s likely just a setting. If you?re using a G3X, there are additional settings for trim in the configuration tool there as well. I imagine Dynon and other AP?s have the same.
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
Old 05-28-2018, 12:17 PM
RV3bpilot's Avatar
RV3bpilot RV3bpilot is offline
Very nice, first flight, Cooooool....
Sorry I don't know anything about electric trim...
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
420 hours and counting
Old 05-28-2018, 03:50 PM
Thanks for inputs. I think it?s like Lenny said the speed power reduction at higher speeds, so I?ll set to a higher limit and see what happens...
Kevin
Old 05-28-2018, 08:42 PM
pilotkms's Avatar
pilotkms pilotkms is offline
Default Dynon?
If u have Dynon Skyview with VPX u need to go thru the calibration procedure. Both need to know which one is in charge. Had same issue with my FLAPS. Made for exciting first flight.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying K
Built in SoCal KCCB, now in GA @ KPXE
800+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019 & 2021
Old 05-29-2018, 09:02 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
If u have a G3X gea24 you need to disable the speed sensitivity in the VPX as shown in the vpx manual
Bill Peyton
RV-10 - 1285 hours
N37CP
First Flight Oct 2012
Aviation Partners, LLC
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
