Brake Line To Firewall?
Is there a drawing that shows how the brake lines are routed from the top of the gear legs to the firewall fittings? I see C2 shows the brake line at the wheel and 36 shows at the rudder pedals. However, I can't seem to find how the solid lines are routed from the gear leg to the F.W. fittings on the RV7. I am probably missing something obvious.
John Johnson
Murphy, NC
RV7
