Old 05-26-2018, 08:55 AM
Bavafa Bavafa is offline
Default Mounting the ADAHAR on the back of G3X
Just wondering if anyone has had any issues mounting the ADAHAR on the back of the G3X screen? I have heard of some possible vibration issue if it is mounted there.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 05-26-2018, 09:49 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Can?t imagine the vibration issues would be any worse. However, if the ADHRS is mounted to the back of the G3X, it would be harder to remove the screen for access to everything else.
My ADHRS isn?t attached to the screen and I?m very glad of it.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 05-26-2018, 12:11 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello Mehrdad,
We designed the GDU 450/455/460/465/470 displays with mounting support for the GSU 25 ADAHRS for those that might want to mount it there and had an instrument panel that was rigid enough where it would work well there.
Unfortunately, many aircraft don't have such a panel. For example, one of the first aircraft to receive a G3X Touch system was Van's RV-12, and even with Van's help, we never could make the instrument panel rigid enough, so had to mount the ADAHRS in another location.
This isn't considered a big deal by many, because most find it convenient to occasionally remove a display to make a big hole in the panel for working on things behind the panel, and it is very convenient to NOT have the ADAHRS mounted to the back of the display with pitot/static/AOA lines.
Garmin's RV-7A has both GSU 25 ADAHRS mounted to the Van's Aircraft RV-7/9 AHRS mount in the tail, which works very well.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 05-26-2018, 12:25 PM
PaulRomano PaulRomano is offline
Hi Mehrad--
I upgraded my F1 last year to an all Garmin G3X based system and struggled to find a remote location for the AHARS due to other packaging constraints. I ended up mounting it to the G3X knowing that I might have to re address the issue, but have had no problems at all.
I do think that it could be very application specific, however.
Paul
Paul Romano
F1 Rocket Sport Wing
Old 05-26-2018, 01:04 PM
n982sx n982sx is offline
Mine is on the back of the PFD in my 14. I've had no issues.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 05-26-2018, 02:06 PM
Thank you all for your feedback. I have tentatively reserved a location n the sub-panel. It would have been very convenient on the back of G3X but it may pose less convenience late on if I have to do any work on behind the penal.
Edit: How accurately does it have to be mounted in relation to the roll and pitch axis? Is 7 degree off from the pitch axis reasonable to do I need to aim to get it far closer?
Mehrdad
Dues paid
Old 05-26-2018, 06:39 PM
sibriggs sibriggs is offline
Default Mounting location
Mounted mine on the G3x also, works great no problems, rock solid and as close to center position as I could get it.
Think I remember at some point reading Garmin set it up to be mounted there, screw holes and all. Not sure why so many folks don?t mount it there?
Steve Briggs. RV9, G3x, G5, VPX, GTN625, PMags, A&P, IA, ATP-CFII
