03-15-2007, 03:58 PM
Vans Primer--What switch are you using?
I'm installing the primer system from Vans (electric) in my RV-6.
Vans kit doesn't recommend or supply a switch to activate it, I guess because it should be a simple install. The switch draws 6 watts which is under one amp by my calculatons.
What are others using to activate the pump?
How are you labeling it?
Seems a push button would be the easiest, just push/hold/release.
there seem to be lots of push buttons available, like a PTT button but these seem small, even though they are rated to handle one amp.
So I was wondering what other have done??
and did you just label it.......
Primer
O
Push to Prime
Wondering here.......Thanks for your help.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
03-15-2007, 05:34 PM
Bob-
I'm currently thinking about my primer switch plans as well. If you're limited on switch space, Bob Nuckoll's has a suggestion to use a three position switch for the primer and boost pump. From bottom to top: off (bottom position) - boost pump (center position) - primer (momentary up position). I don't think I'm going to do this because I'm not limited on space and because I want the primer over on the far left since the only time I use it is on start-up. I want my boost pump over by the flap switch and throttle. Just another option though for you to mull over. I'm interested to hear other options too. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
03-15-2007, 07:07 PM
Guarded switch
Here's the one we've been using, from ACS:
OFF-(ON), 5 AMP
Mounting Hole: 1/2"
Aluminum Guard
P/N 15-112 $8.40
Wire it so it's only active when the fuel pump is switched on. While it's hard to see in the picture, the guard helps to prevent it from accidently being pushed. Guard also helps in quick identification.
Just one solution, many others I'm sure!
Bill Waters
Based KCVC (Covington, GA)
RV6A - Gone, but not forgotten!
RV8 - Gone too, now winning races in the RV Gold Class!
RV4 - Flying!!!
03-15-2007, 07:42 PM
VAF Moderator / Line Boy
Guarded Momentary Toggle
Mine is exactly like Bill stated above, and it's locate just to the left of the Boost Pump switch, directly in front of the throttle on my -8.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
03-16-2007, 06:50 AM
Switch
Thanks for the information guys!
Wiring so that the primer can only function while the boost pump is on, is a great idea that I hadn't thought of. Just another built in safety feature.
Thanks again.
Bob Martin
03-16-2007, 07:22 AM
Mine is installed per 'lectric Bob's suggestion. One toggle for boost and momentary position for prime. Works great.
In the early hours of my phase 1 at about 800 agl, I accidentally hit the primer thinking it was the flaps. I am not sure why because the boost/prime is on the left of my panel and flaps are towards the middle above the throttle. Engine sputtered for a split second and really got my attention! Since then I installed color coded covers on all toggles and after 70 hrs can now hit the correct switches without looking.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
03-16-2007, 07:29 AM
Switch or Push button
Awhile back there was a discussion about the ability to use your primer lines to keep the engine running in the event that there was a problem with your main fuel delivery system.
If you have a multi cylinder primer system you might want consider going with a toggle switch rather than a push button.
With a toggle switch you could leave the solenoid valve open to continuously deliver fuel to 3 cylinders.
Mike Draper
RV-8 Finish
03-16-2007, 09:17 AM
Primer switch
Mike Draper
RV-8 Finish
Thanks for replys.
I do have a 4 cyl primer system.
The primer pump/solenoid does 25 psi I think.
Not sure if the 'system' would actually run the engine if left on???
seems the chance of inadvertnatly leaving the toggle "on" would be a bigger risk than using the button in an emergency.
But maybe the toggle under the red cover would reduce the possibility of leaving the toggle switch on?
Bob Martin
03-16-2007, 10:22 AM
I had decided to not install a primer system, but I have recently heard the discussion about the alternative fuel delivery possibilities in an emergency, so now I'm reconsidering my decision. I've not seen a picture of an installation, where does the Van's primer system get plumbed in? I believe my Aerosport engine came with primer lines installed. I haven't unwrapped the engine yet to look.
Mike Doyle
RV-12
RV-9A, Under Construction
Xenia, OH 45385
03-16-2007, 12:56 PM
Primer install
Mike,
The primer system starts at the top of the gascolator with 1/8" fitting and routes with copper tubbing (normally) via tee, etc to the 1/8 port on the Intake side of the cylinder head. There is a port on top and another on the bottom. The top one is usually used for Fuel Injection. sometimes you will see the manifold pressure tapped off a lower port, otherwise they are plugged up.
Vans kit is designed with flare type fitting and 1/8" copper tubing enough for two cylinders as well as the electric solenoid.
It does really help to look at one to visually understand it.
The hardest part seems to be where to mount the fittings, like the tees or in my case a 4 way spliter. Remember to bend up a coil for vibration between the engine and the firewall side of the installation.
Hope this helps
Bob Martin
Bob Martin
