05-23-2018, 08:18 AM
Antisplat Oil Seperator
I recently installed the oil seperator on my RV7 which always had a little more blow by than my other plane probably due to higher compression ratio. I was constantly cleaning the belly and got tired of doing so. It is an awesome product and after 5 hrs of flight the belly looks perfectly clean. It was an easy install and I am sure will also cut down oil consumption. Money well spent and with their install kit iy was easy to drill out the hole in the exhaust also
05-23-2018, 08:38 AM
Senior Curmudgeon
Are you aware of the need to do periodic checks on the exhaust fitting to be sure it hasn't "coked" up?
Also, are you aware of the secondary relief port some folks have installed in the suction line?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
05-23-2018, 02:19 PM
?.All vacuum kits sold, include the bypass valve pre-installed
in the plumbing. They also include instructions on installation
and regular maintenance. Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & ServicesInfo@AntiSplatAero.com Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
05-23-2018, 03:42 PM
Not exactly....
My (very early production) kit did not have the bypass valve. I ordered it later and installed it separately.
05-23-2018, 04:25 PM
Yes the instructions are clear re inspecting for coking. Mines really easy to get to and will do on each oil change.
05-23-2018, 05:05 PM
Senior Curmudgeon
….All vacuum kits sold, include the bypass valve pre-installed
OK, got it. I was not aware you had started including these with the system. I remembered that a few years back there were issues.......
Looks like you grabbed the bull by the horns and addressed those issues.
Good job.
Mike Starkey
VAF 909
Rv-10, N210LM.
