Old 05-22-2018, 11:24 PM
ron sterba ron sterba is offline
Question Dynon Skyview. EMS 37 pin connector
Wanting to hook up pin number one which is red in color for a voltage reading. The 26 gauge wire comes in the harness where would you hook up that wire to find out what your voltage.? I have ATC fuse block.(20 fuses). I thought about the main terminal of the fuse block but was wondering with the amperage at the fuse block with that 26 gauge wire be damaged? ? I am looking in the manual installation guide volt meter set up and question number two there are five ranges that you can select for different voltage gauges,I have a 12 V system. appreciate your thoughts.thanks
Ron RV9A
Old 05-23-2018, 12:13 AM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Default Current
Professional electronics guys will laugh at me for this, but I would describe it this way:
Amperage (Current) is pulled in a circuit, not pushed. In other words, the current in that wire will only be what the Dynon requests (which is negligible). So the small wire can be hooked to any place that has a valid voltage.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 05-23-2018, 05:29 AM
Jesse's Avatar
Jesse Jesse is offline
It?s a 22 gauge wire in the Dynon harness. It can be hooked anywhere that has voltage, but it certainly wouldn?t hurt to have it run through a fuse.
Jesse Saint
Old 05-23-2018, 10:25 AM
Raymo's Avatar
Raymo Raymo is offline
The OP may be referencing the Dynon manual's suggestion for either a 1 amp fuse or a short piece of 26 gauge wire, which would melt should there be a short.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 05-23-2018, 12:07 PM
Thanks Chuck,Jesse & Ray. Ok will hook up to something fused. My lead is close to my nav Light switch that has a vacant spade. If I hook it up here would you suggest a one amp fuse off that switch to the red lead?
Then my next question is on the those 5 voltage variables normal/caution ranges gauge listed in Dynon’s installation manual on the Skyview 10 Touch which one should I select? Again 12volt Odessy battery is what’s in my 9A.
Yes I have been flying for 20months without the voltage. Never did hook up. Current was the most important because if there was a change in current statis in our wiring you would want to get down very so where as if you relied on the voltage you could have normal voltage up until the last amp and you might not have a working radio on your way back. It’s my passengers who look at the gauge and say “your voltage reads zero” a little concerning to those sitting right seat!
Old 05-23-2018, 12:51 PM
RV7A Flyer's Avatar
Don't have the manual in front of me, but isn't that for the Ammeter shunt?
2019 Dues paid!
Old 05-23-2018, 01:23 PM
airguy's Avatar
airguy airguy is offline
It is, but for voltage sensing it will serve the same purpose.
Old 05-23-2018, 01:32 PM
Raymo's Avatar
Yes, 1 to 5 amps for 22g wire with 1 being sufficient for this connection..
Then my next question is on the those 5 voltage variables normal/caution ranges gauge listed in Dynon?s installation manual on the Skyview 10 Touch which one should I select? Again 12volt Odessy battery is what?s in my 9A.
If referring to the 5 volts OUT to sensors, they typically share that line for oil, fuel and manifold pressure.
Responses above.
Ray
Old 05-23-2018, 01:33 PM
Raymo's Avatar
You are correct. I supposed the same could be done for this connection as well but why not use a fuse...
Ray
Old 05-23-2018, 03:56 PM
Chuck I like that analogy. Sometimes one is more inspiring than another. This one works for me thanks
