I pull hinge bolts at my 500 hour inspection. I have only done it once and did not find any wear at all, none, zip, zero.
For cleaning hinges, hinge bolts, etc... while installed, I use LPS-1 then follow up with LPS-2. The LPS-1 seems to flush out the dirt, grime, and old lubricant. Using LPS-1 instead of a solvent I don’t worry about solvent contamination if I don’t get it all out.
I use the can and keep the little red plastic “nozzle” on so I have a good pressure stream to help flush out the joint. Put a rag under to keep the mess contained.
LPS-2 does attract dirt but it also stays put. LPS-1 doesnt seems to hang around long enough and there have been reports from others that it did not protect well.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
