Old 05-18-2018, 08:51 AM
PilotjohnS PilotjohnS is offline
Default Protecting Interior Paint
Seeking advice from those who have gone before.
I plan to paint the interior pieces as I build. But how to I protect those pieces during the rest of the build. I plan to use Jet Flex , so it is pretty durable and supposably there is touch up paint available.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
www.pilotjohnsrv9.blogspot.com
Old 05-18-2018, 09:33 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I build out everything, take it all out, paint what I can outside the plane, paint the rest as is in the plane, then reassemble.
The planes I?ve seen with the interior painted along the way all looked worse for wear.
Carl
Old 05-18-2018, 09:50 AM
wirejock's Avatar
wirejock wirejock is offline
Default Paint
Carl
Basically what I did. Everything painted before assembly. Rivets show. Jet Flex Solvent Based.
I do have a couple scratches to touch up but so far it's pretty tough.
Not much help if it's already assembled.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-18-2018, 10:17 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
If it's JetFlex WR it will touch up well with simply an airbrush or small touchup HVLP sprayer. Just use your original paint.
The flat finish helps make the touched up edges disappear.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-18-2018, 10:25 AM
bkervaski's Avatar
bkervaski bkervaski is offline
Masking tape .. probably the #1 consumable we've used. We have it over all the traffic areas. Still have some scratches (from the canopy hitting the roll bar) but overall it's worked great.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 05-18-2018, 10:55 AM
Paddy's Avatar
Paddy Paddy is offline
Default Jetflex WR
I'd second Gil's comments about Jetflex WR. Surprisingly durable and easy to touch up, especially with the flattener added. Even so, it's probably a good idea to protect the high traffic areas with tape, I do have a few scuffs and scratches on the door sills etc that I never got around to fixing after getting the plane flying. Amazing how priorities change after the fun really starts!
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Atlantic crossings: 2
bruceh's Avatar
bruceh bruceh is offline
I didn't really have any issues with the JetFlex WR durability during the build process. I painted the interior pieces before assembly. The only advice I can give is let the JetFlex set up for 24-48 hours before you rivet any parts together. After it completely cures/dries, it is very durable.
Bruce Hill
2020 VAF donator
Old 05-18-2018, 02:14 PM
Default Thanks for the responses
I have been agonizing over this for weeks. My wife said ?Dont worry about it, you wont see it from an airplane.? I said, ? Yes i will see it from an airplane?.
This morning I had decided to paint efore assembly, hence the reason I asked the question. But now I know it is going to get scuffed up. I think I will take Carl?s advice and paint after assembly.
Thanks for the feedback.
John S
RV9A- Status:
Tail 98% done
Wings 98% done
