Sounds like you previously had the prop/engine balanced. I'm not an expert on the topic but would think the flywheel is balanced when manufactured and you could install the same weight that was there but, IMO, it would be best to just re-balance. Necessary? No.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
