yes
Yes, there are different springs available to increase or decrease the oil pressure. A call to Lycoming Tech support should be able to get you the correct part numbers.
I would make sure the pressure is reading accurately with a direct pressure gauge prior to making any changes.
You could also take it apart and make sure that there aren't washers in there already that you could remove.
Be careful when taking it off that you don't loose the little ball bearing.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Reason: added verbiage
