Old 05-13-2018, 07:47 PM
Scott Hersha Scott Hersha is offline
Default Van?s fuel level sender
Seeking help from the group....
I have recently finished and flown my new RV8 and I?m having strange indications from my left tank float fuel level sender. Sometimes it indicates correctly, but then it will suddenly go to zero, or some very low value. I know the tank is full, or nearly so when this happens. At first I thought the float was sticking, even though I was very careful when installing it. But then I thought, how could a float in a full tank suddenly sink to the bottom and stick there? I?m flying in smooth air at 1g and the indication ?sinks? to read zero. I have a G3X touch and I think it sends a 5v signal through the sensor wire to read resistance(?), so what could cause this indication? Before I go through the, not fun, job of scraping off proseal in the confined wing root area to remove the offending sender (I?m NOT removing my fuel tank), does anyone have suggestions for a possibly easier fix. Has anyone else experienced this indication?
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 05-13-2018, 07:53 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
As the level changes shaply, it sounds like a wiring issue.
As you check the wiring, don?t forget to verify the sender case is really grounded. If not, run a separate ground lead to a wire with a ring connector under one of the sender screw heads.
Carl
