Old 03-14-2007, 08:02 AM
rv72004 rv72004 is offline
Default De-riveting skin without damage??
Is it possible or improbable to remove [derivet] a whole wing skin without damaging / enlarging the holes in the ribs ???
Or will I end up with a bunch of oops rivets ?
EJ
Old 03-14-2007, 08:07 AM
JonJay's Avatar
JonJay JonJay is offline
EJ
Very doable. Make sure you are using the proper technique; do not drill through the whole rivet, only the head. Use a proper punch to gently pry/snap off the head. The rivet should fall right out, once the head is off. If it doesn't, move on. When the skin is finally off, you can clean up the ribs.
It will be a lot of work, but probably not as bad as you might think.
I must ask why your would do this though.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-14-2007, 08:45 AM
TSwezey TSwezey is offline
Use a little smaller drill bit maybe a 41 instead of a 40. And follow previous posters instructions.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 03-14-2007, 09:00 AM
pierre smith's Avatar
Default Easy answer....
Originally Posted by JonJay
Very doable.
Jonjay,
I bought a -4 empennage sight unseen for a really good price, already built. After a more thorough examination, almost all the rivets on one skin of the stab were not down flush (on the spar) and if I shaved them, wouldn't have enough head left. Solution....a few hours work drilling them out and re-rivetting.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-14-2007, 10:46 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default the holes
the holes will get bigger in the thin stuff like ribs. .025 or less seems to be a pain. they simply stretch when the rivet is driven. can be done however with little or no problem if done with care.....
William Weesner/ still kicking.
Old 03-14-2007, 11:04 AM
thallock thallock is offline
So, the concensus is that this can be done, if you are careful. The real question is why? Come on, EJ, we all want to know. This is like a support group. You know, hello, my name is Tracy, and I punched holes in my wing skin with the C-Frame (actually, I dd it to my tanks, ouch!). So, EJ, what's your story?
Tracy.
Tracy Hallock
Austin, Tx
RV-7(EH) - Fuselage
http://www.trv7.com
Old 03-14-2007, 12:38 PM
rvator51's Avatar
rvator51 rvator51 is offline
One reason is if the rear spar attach hole to the fuselage is incorrect which makes your wing angle of incidence wrong. If you make a new rear spar attach bracket, you have to remove part of the skin to get access to rivet it back on. Dont ask how I know.
Tracy.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 03-14-2007, 01:01 PM
N941WR's Avatar
N941WR N941WR is offline
...will I end up with a bunch of oops rivets ?
EJ
Don't use oops rivets, the small head can pull through. If you need to upsize the hole to 30, then dimple the hole with a pop-rivet dimpler and put the larger rivet in. Not a big deal.
Good luck.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
