Old 05-07-2018, 07:49 PM
dmat dmat is offline
Default Oil in new fuel divider?
Hey all,
I?m in the process of installing a fuel injection system in my 6a and was plugging up 2 ports in my fuel divider. When I pulled the nozzle line fittings out to plug them I noticed oil running out. I just got it back from afp for a flow test.
My question is, do I need to bleed out the oil before I hook the lines up to the cylinders?
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
Old 05-08-2018, 08:38 AM
Raymo's Avatar
Raymo Raymo is offline
You can call Don and ask but I just hooked things up since it was going to be a while before the engine ran and the oil keeps things lubricated. It will burn off once you start the engine.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
