03-13-2007, 09:22 PM
Where to buy SS tubing for Fuel Injection?
I need to buy some 1/8" stainless steel tubing. the same size and type used for Fuel Injection systems.
I can't find it in ACS Catalog.
also need the ferrules and fittings to go along with it.
Anybody know where I can find it??
My RV-6 (purchsed) has a primer system using the SS tubing.
I'm moving my oil cooler to the rear baffel of #4 cyl and need to reroute the primer lines and need new tubing to do it.
Thanks in advance for your help.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
03-13-2007, 09:26 PM
Multiple posts
Sorry for multiple posts, I'm on a sat connection and it was telling me the post wasn't going thru......
aparently it WAS!!
Hopfully a moderator will delete them.
Bob Martin
03-14-2007, 12:25 PM
I run a lot of 1/4" OD 316 stainless, .035 wall thickness, .180 ID. Rated for 10,000 psi, way overkill for this application, but it's light, cheap, readily available, and easy to hand-form.
PM me if you want some...
03-14-2007, 01:37 PM
Wicks....
If 304 grade SS is OK, then Wicks has it in 1/8 x 0.020.
http://www.wicksaircraft.com/catalog...835/index.html
Can an engine guy tell us what the grade of SS should be?
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
