I'm pretty sure the #6 screw hole is a #28 bit. At least, that is the size I drill to for use with my nutplate jig. Drilling to #24 or #21 would then provide plenty of room for expansion.
However, if you go the Sika route, no or few holes will be drilled in the plexi. The only holes in my canopy are along the upper edge of the side skirts.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
