  #11
Old 05-07-2018, 08:42 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default Thanks!
Appreciate the replies, fellows.
Fast running out of things to do closing out the control surface end ribs with foam/glass/micro - and I'll need to order windows soon in order to keep on with the build.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 05-08-2018, 10:28 PM
ReidVaitor ReidVaitor is offline
Default Desser Cee Baileys
If you're going to order the windows, consider that Cee Baileys is owned by Desser so think about getting the tires and leak proof tubes while your at it. My retreads have no shake to them (happened on landings with Vans stock classics) and are lasting twice as long as the Vans aeroclassics did.
As for the windows- believe me when I tell you, anything you have to do with the cee baileys acrylic will be 10X less than the cutting and trimming needed for the stuff Vans sends and the quality is far improved for clarity. It fits, as is and as someone else mentioned, I did need to use a washer in a few places to lift the plenty to be flush in high spots. You wont have a oversized issue with these windows!
Best of success
P
