As Bevan suggested...
In my slider, I punched a small hole in the turtle deck side support and slipped the rubber tip through.. It will easily pop out with a little disturbance.
You will need to notch the flap mechanism cover a little
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
