Closed Thread
Old 05-01-2018, 03:37 PM
Rodoc's Avatar
Rodoc Rodoc is offline
Default NEW FAI Time to Climb Record!
Hi All,
I just wanted to share that a few days ago Daniel Gray crushed (by 19 seconds) the FAI Time to Climb to 3000M record in a Harmon Rocket using a 2-Rotor Mazda Rotary engine. With a time of 1 min 40 sec.
Older records here.
Here is a video.
They bought a used H. Rocket, sold the aircraft engine, then installed a turbo 2-rotor rotary and optimized everything for the time to climb. They were getting about 650hp from the 2-rotor engine block that weighs less than 200lbs.
Note that this new record beats all the records in all classes of internal combustion engine powered aircraft.
David "Rodoc" Leonard
Turbo Rotary RV-6
Oceanside CA
www.n4vy.rotaryroster.net
Old 05-01-2018, 04:25 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Originally Posted by Rodoc View Post
Hi All,
Older records here.
Here is a video.
Already being discussed here:
http://www.vansairforce.com/communit...d.php?t=159916
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 05-01-2018, 05:32 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Not yet. As discussed in the other thread, it falls short of the outright record at 91.9 seconds held by Lyle Shelton in Rare Bear.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Closed Thread
