Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
Old 04-29-2018, 07:25 PM
RandyAB RandyAB is offline
Default Fuel filter in engine compartment?
I'm planning out my fuel system for use with my SDS system and was wondering if it were ok to mount the Holley post-pump fuel filter on the engine side of the firewall to keep it out of the tunnel? I can't find temperature range data on these filters. Any potential adverse effects to consider?
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 04-29-2018, 08:12 PM
Bevan Bevan is offline
Randy,
Based on a conversation I had with Airflow Performance when I was in your shoes, they strongly recommended against putting the filter in the engine area. You want to minimize fuel volume in the engine area and any potential for it to pick up heat before the engine driven fuel pump. This includes filters, gascolators, fuel lines. Any of these which must be FWF, should be protected from heat with fire sleeve.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 04-29-2018, 08:25 PM
Originally Posted by Bevan View Post
Randy,
Bevan
Thanks Beven. With the EFI, the fuel pump would be in the tunnel before the filter.
Randy P.
1st time builder
Reserved:C-GRPY
Old 04-29-2018, 08:35 PM
Originally Posted by johnbright View Post
SDS recirculates fuel to tank.
Ask Ross Farnham.
I will. I'm always bugging Ross with questions so I thought I would ask the forum first.
Randy P.
1st time builder
Reserved:C-GRPY
Old 04-29-2018, 09:42 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
This is opposite of convention; filter then fuel pump.
Carl
Old 04-29-2018, 10:51 PM
Toobuilder's Avatar
I have my off the shelf GM FI filter in the engine compartment. This is downstream of the pump just as with millions of GM cars with billions of hours collectively. I do have a pre screen to keep the trash out of the pump, but I think the main concern is protecting the injectors before the pump.
In my system, minimizing suction losses is paramount.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 04-30-2018, 07:46 AM
Carl
There is a pre filter as well. In this case, two of them, one in each wing root.
Randy P.
1st time builder
Reserved:C-GRPY
Old 04-30-2018, 09:29 AM
Ralph Inkster Ralph Inkster is offline
I have had great results with SDS systems with a filter ahead of the pumps, pump, and gascolator after the pump arrangement.
One instance we experienced- the Andair gascolator saved the day by catching debris from a failing pump before it could advance further thru the rest of the system. This arrangement made the situation very detectable prior to a total pump failure, unlike a closed filter that wouldn't have been looked at probably till the next annual, or after a failure mode.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 04-30-2018, 09:55 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
With your pre-pump filters in the wing roots, you won't spill fuel inside the cabin when you check them. Not a bad plus.
There is no issue placing the post pump filter in the engine bay. As John said, we recirculate the fuel so there is no chance of heating the fuel up much like a non-return type Bendix FI system might.
Be mindful of extra restrictions before the pumps. We don't like to see gascolators mounted there unless they are your only pre-filter. If you must use a gascolator, using a high pressure one downstream of the pumps is the preference.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 01-21-2019, 10:18 AM
charosenz's Avatar
charosenz charosenz is offline
Good discussion.
So my take from reading this and other discussions is that I am leaning towards, a 6-10u micron filter after the pump but inside the cab in the tunnel.
It took a while but I found WIX 33279 and BOSCH 71020 filters that have threaded ends in the 12mm-14mm size (not push on). Then a pre-filter in the wing root outside. Probably 30-100 micron.
I am still debating the option of a High Pressure gascolator. I do like the thought of being able to drain fuel to check for water. May be just "habit" from years of flying spam cans. But I also like the simplicity of leaving it out all together.
Comments welcome.
Charlie
