Old 04-28-2018, 05:32 PM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
Default spark plug washer heat treat method
I don't buy new spark plug washers. For spark plug changes I heat treat the used washers with a torch until red hot and let them air cool to make them soft again. Thereby saving the planet and added expense. But today, I didn't have my torch so what to do? Well, I have a hot plate so I thought I would give it a try. I tried bending a used washer firstly and yes it was stiff, as I thought it would be since I have checked them before in this condition. Then I put the washers on the hot plate for 10 minutes. They become black but once air cooled and shaken together, the black oxides falls off and they are supple once again. This is my new method. Forget the torch.
bent with fingers
BTW: spark plugs at 650 hrs as removed. except for one that was replaced because it was dropped, #2 down. they look OK.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 04-28-2018, 06:29 PM
Two comments:
1. Unlike iron, you can dump the copper into a water bucket after heating. It will still be soft, but less black scale.
2. #4 bottom plug, maybe others, look to me to be near the end of their service life - center electrode looks to have a 2:1 aspect ratio.
Old 04-28-2018, 06:54 PM
Originally Posted by BobTurner View Post
Two comments:
thanks for the note on #4 bottom plug, time for that one to be replaced.
Steve Melton
Cincinnati, OH
Old 04-28-2018, 08:16 PM
JonJay's Avatar
JonJay JonJay is offline
Good idea. I recently changed out the new “old” hangar trucks power steering pump. The main hose fitting is a bango fitting that has two new copper compression washers that come with it. I couldn’t get them to seal to save my life. Heated them with my torch (careful, they are easy to melt), and they sealed well. You can feel the difference as you torque them down.
Might need to find a hot plate.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 04-29-2018, 12:13 AM
Plummit's Avatar
Plummit Plummit is offline
With the cost of electricity added to the labor to heat-treat the washers, I'll save more $$$ buying stock of washers and just using new each time I pull a plug.
-Marc
RV-10
N814RV
2020 Donation Made
Old 04-29-2018, 05:16 AM
vic syracuse vic syracuse is offline
Super Moderator
Default Take a harder look
Quite honestly, I would be replacing all of them (except for number 2). They are definitely footballed. Did you check for resistance?
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 04-29-2018, 05:42 AM
Electricity is less than a nickel to heat treat these. I also regrind my wire flush cutters when they become dull.
-Marc
Steve Melton
Cincinnati, OH
Old 04-29-2018, 09:38 AM
RV6_flyer's Avatar
Vic
IF the plugs were in my hangar, I would use a spark plug erosion gauge to see if they are still in mechanical spec as well as do a resistance check.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-29-2018, 11:13 AM
Sam Buchanan's Avatar
been here awhile
That was my thought as well, and it appears to me seven of the plugs would fail the erosion test.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 04-29-2018, 05:58 PM
resistance check was fine and you can see the plugs have a nice color to them. for the most worn plug: wide diameter = .142 inch, minimum narrow diameter = .122 inch. so appearance is worse than it actually is. I reinstalled as is. I can get more life from these but placed an order for a new set to be ready in another 100 hrs.
Steve Melton
Cincinnati, OH
