Old 04-26-2018, 05:04 PM
jimevison jimevison is offline
Default Slider canopy latch question
When closing a slider canopy, the outer handle can collide with the fiberglass surrounding the windshield. This will only happen if the handle is left 180 degrees opposed to the closed position. I'm concerned this could damage the fiberglass. Is there a mechanism to limit the arc of the handle to prevent it rotating full circle?
Old 04-26-2018, 05:25 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
If you look at the drawings you should find instructions to taper the bottom of the handle for precisely the purpose of not hitting the fiberglass.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
