Go Back   VAF Forums > Main > Safety
Old 04-25-2018, 08:57 AM
Walt's Avatar
Walt Walt is online now
Default Check those Rudder/Elevator Counter Weight Bolts!
Make sure you are checking that your counter weights are secured and the bolts are tight during your inspections. This one required quite a bit of work to access, but the loose counter weight screws were hanging down and almost ready to jam the rudder
The same precaution holds true for the elevator weights.
This is not the first time I've run into this.
PS: the big cut out was required because there is a bulkhead that had to have holes drilled in it to access the nuts, these tall rudders have these nuts buried pretty good.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 04-25-2018, 03:42 PM
Good advice. Should be a part of every preflight inspection.
If you're still building, make a backing plate with two nutplates behind each counterweight, so you won't need to make an access hole to tighten the bolts.
Doug
RV-9A "slider"--sold in July 2021
Donation made for 2021
Old 04-25-2018, 08:16 PM
arffguy arffguy is offline
Since I learned about this recently I have told every RV owner I know.
Previous threads:
First one is from October 2012. How did I miss that one?
http://www.vansairforce.com/communit...st704407<br />
http://www.vansairforce.com/communit...d.php?t=116779
There is a good image here of the new RV-14 parts:
http://www.vansairforce.com/communit...d.php?t=159464
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid anyway
Old 04-25-2018, 08:37 PM
Steve Melton's Avatar
nice paint. at least your cuts are straight.
it may be possible to use the cut out piece in the repair?
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
