Go Back   VAF Forums > Model Specific > RV-14
  #11
Old 04-24-2018, 10:08 PM
RandyAB RandyAB is offline
Originally Posted by iamtheari View Post
That DTM connector is a thing of beauty. Do you have a recommended source in the US?
http://www.te.com/usa-en/home.html
They are beautiful but the crimpers are extremely $$$.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 04-25-2018, 05:04 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Default Use DSUB pins and heatshrink
I used the simple, reliable, cheap and lightweight method by using DSUB pins covered in heatshrink:
(Pics below are on an EGT wire, but this applies to any wires you need to connect).
It's about as low-profile of a connection as you can get, and still serviceable with basic aviation electrical tools.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 04-25-2018, 06:01 AM
Tom Martin Tom Martin is offline
If there is enough wire to leave a small service loop, then forget the connector and use butt splice connectors, solder core if you have them. This is not an area that will require disassembly and if so, the service loop will accommodate that. Terminal connectors, like the molex plug, are just a place for issues years into service. Keep things simple.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 04-25-2018, 06:38 AM
BillL BillL is offline
Default Just a thought.
I use the Stein tool for these split terminals and initially had some that did not want to click in. I found the thickness of the tool (length along the terminal) was critical and just a few thousands too close to the pin end, would crush the housing and destroy the retention function. I used a headband magnifier to ensure proper placement and did not have the issue again.
Bill
RV-7
Lord Kelvin:
Old 04-25-2018, 08:08 AM
iamtheari iamtheari is offline
In this instance, although I already ordered the pins and connector from Digikey, I'll just eat the $6.00 and eliminate C409P/J by using butt splices from the servo to WH-00073 (the short harness supplied in the kit to get out of the elevator and into the tailcone. I will retain C429P/J so that the elevator can be disconnected from WH-00057 (the aft fuselage wiring harness) when needed.
Incidentally, I found a mistake in the plans while writing this post: Page 10-25, revision 0, figure 2 says to label the connectors on WH-00057 as C410P and C409P. The latter should be C429P. See page 09-24, revision 0, figures 3 and 5. (This is not egregious. It's very obvious what is going on in the plans. My OCD just catches things like that, teh typo in the title of figure 1 on page 10-21, and the fact that page 10-22 does not have steps 4 or 5.)
Old 04-26-2018, 05:06 AM
Steve Melton's Avatar
I used wirecare.com but you may find them other places less expensive.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
