The obvious solution John, is to get rid of the gear doors and keep the gear down and welded like a 'proper' airplane.....
But seriously when I built my 7A, all the hinge supplied by Vans was the rolled variety not the much stronger extruded style you are using. Not sure if this has been the case for all RVs. I just know what I received which matched the prints. I did put some extruded hinge in a couple of spots on my cowl that I wanted extra strength and more flange length.
No problems yet after 700 hrs but my hinges are not taking the beating that yours are.
Come to think of it... The hinge supplied for the cowl to fuselage joint was much heavier variety, still rolled though. Might be an option but you would have to replace both halves. If I see you at the hanger we can look up the part on my prints. I think it is non-aviation hinge but memory could be off.
Good luck, friend.
