Old 04-21-2018, 11:34 AM
BillL BillL is offline
Default Hot, start, Click ???? Anyone else?
Short version: flew - landed, sat 20 min, lack of starter engagement on restart. Click - -
Anyone else had this happen with the SkyTec LW starter?
Long Version background:
RV7 - SJ Cowl
YIO-360 M1B - stock - w/SkyTec LW starter
14 hours into PH I
Moderate OAT 45 F, flew 45 min made a good landing and decided take a water break. The plane sat with no wind for 30 min, then got to starting - just a click, 10 times ( maybe more, it was a lot) Click- clearly the start contactor on the firewall, but no other sounds. Finally, kept up the attempts and it engaged and spun and started. Until that, nothing but clicks. The voltage did not drop either.
The plan is to decowl and run some wires to test voltage:
1. to starter via large cable,
2. voltage to the start engage wire from the FW contractor.
In addition, place a thermocouple on the starter solenoid (for SkyTec techs)
Possible issues:
Bad FW Starter contactor - not passing voltage to starter
Hot starter solenoid - needing more voltage for pull in than available
I pull tested all the big terminals by hanging (me) from them. Book pull test is 525 lbs and granted I am only 150, but not loose. This only happens when it is hot, this is the second time for the click event.
Bill
RV-7
Old 04-21-2018, 11:39 AM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
Sounds like the starter solenoid on the starter...
http://www.vansairforce.com/communit...ight=Crown+vic
Bruce, Katie, Hana and RV-8 HulaGirl
Old 04-21-2018, 12:14 PM
AviatorJ AviatorJ is offline
Is it a single click and then nothing? I had an issue on my 172 where the skytec starter cracked which messed up the pinon alignment. The clicking I heard was the pinon slamming into the ring gear trying to engage. Replaced started and ring gear, no other issues.
Justin
RV-10, N10JW
Flying since 2/14/2019
http://operationrv10.blogspot.com/
Old 04-21-2018, 01:52 PM
Mark H's Avatar
Mark H Mark H is offline
I had this issue on my plane just a few hours into phase I as well. I have a YIO-360-M1B with a Skytec LW starter. I ran multiple tests to find the problem and concluded the solenoid was bad. It appears to be somewhat of a common problem from searching the forums. I called SkyTec and they were quick to have me ship it back to them, however, after they received it I was told it tested within their specifications on their bench. This greatly confused and frustrated me, but to their credit they did warrant the starter and sent me a new one after about a week long discussion. In hindsight I wish I had done more tests before I shipped the starter off. It looked like the solenoid was weak and would not engage unless the ring gear was aligned precisely with the pinion gear. I had installed the started exactly as Van's recommends. There has been much discussion about whether or not to remove the jumper that comes on the SkyTec starters. I think there is good reason to remove the jumper, and separate the wiring of the solenoid and the starter, but my theory is that the size of wire used for the solenoid is often not large enough to allow enough amps to flow to the solenoid causing it to lack the power it needs to engage. I have found that the initial current draw for the solenoid can be higher than one might think. I decided to wire the new starter with the jumper installed. I cannot say for sure what my original problem was, but SkyTec said there was nothing wrong with my starter and I have not had any issues with it since. Good luck and let us know what you find.
Mark Hansen
Indianapolis, IN
RV-7A N896PS - Flying as 10/19/2017
RV-10 Under Construction
Old 04-21-2018, 02:29 PM
rv7charlie rv7charlie is offline
With the cowl off, you should be able to hear the difference between (among) a starter contactor (the thing on the firewall that looks similar to your master contactor), the actual starter *solenoid* (on the side of the starter).
Since some installs don't have a starter contactor (using instead, a heavy duty PB on instrument panel directly activates the starter solenoid, which completes the high current circuit on the starter), that may color what you hear.
Some starters use a lever controlled by the starter solenoid to move the pinion; some use a 'worm' gear to move it forward as the starter starts to spin.
If you hear a 'clack' but get no prop motion at all, odds are that either the contactor contacts or solenoid contacts are bad.
Don't forget that either a weak battery, or poor connection anywhere between the battery + & battery - terminals can give the same symptoms. If there's no voltage drop when you activate the starter, every connection, in addition to the contacts in the contactor and the solenoid, are suspects.
Old 04-21-2018, 02:47 PM
131RB 131RB is offline
I went through the same issue with the same starter on my rocket last year. The starter had less than 200 hrs since overhaul. Replaced the solenoid no help. Replaced starter with a brand new NL starter no problems since.
I don?t pretend to know the inner workings of the starter but the old one for lack of a better term seemed to have a dead spot.
Ryan
Old 04-21-2018, 04:23 PM
Tom Martin Tom Martin is offline
The light weight skytec starters are hard on solenoids. You can take the starter to any automotive starter/alternator shop and they will have off the shelf parts to fix it. The only thing aviation about the starter is the casting, the rest is stock automative parts.
After a few years of this nonsense I replaced the unit with geared starter, I believe it might be KPS? This is a much better unit, does not spin the engine quite as fast but has been trouble free. Aside from the casting the electoral and geared portion are exactly like the unit that is on my 35 year old Toyota forklift. Again parts are off the shelf at auto shops.
I have heard good things about the longer inline starter; It just would not fit my installation as easily as the geared version.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 04-21-2018, 05:20 PM
olyolson's Avatar
olyolson olyolson is offline
Default Starter
I have an AEIO-360 & C/S on my -4 and had a Skytec lightweight 149 on it. After 3 starters barely cranking and frying themselves I switched to a 149NL high torque starter with no issues since. No idea why the original builder put such a light starter on the airplane.
RV-8, Aerosport IO-360M1B, MT 3 blade, AFS 5500
RV grin every flight
"Sure is nice to have smart friends"
Old 04-21-2018, 05:21 PM
Thanks Bruce and Mark, since this only happens after a hot shut down and soak, and others have had the issue it seems a higher probability. I'll prepare an extra, larger gauge, wire for the solenoid, that is a good comment. And some old experience with VW 6 volt starters comes to play. I will also add grounding to my list, even though I have a solid case ground.
Remember, I have had zero issues with all the starts when cool. If it were a gear lead relief issue it should have surfaced at least once when cool. The starter contactor is Vans standard, wired exactly like they recommend. Having tried it many times before success, I am pretty sure there was only the firewall solenoid clicking. But I will inspect the pinion face to be sure. I was reading the voltage in two places. One is directly connected to the master contactor, the other is off the buss internally on the Dynon D6. The Dynon read 12.4 volts. It stayed there when held in start position before and after the click.
Thanks for all the comments, I searched a couple of ways and did not find a low hour, hot only, solenoid issue. I am loathe to replace any parts on a stock, new, starter that is supplied by Lycoming to do this job. When it works, it always spins well and has never kicked back. Even after the click event, when engaged it spun a hot IO engine fast and it started/fired in a couple of blades. I am going to work with SkyTec technical staff to get data they are happy with. Hopefully, the parts can pass in the mail. Waiting a week is not good just when the weather is getting flyable.
I have thermocouples in a lot of places, so adding one to the solenoid is a non- issue. Too bad a DAQ unit is not owned to record them all simultaneously.
I'll keep you posted, Thanks Again VAF!!
Bill
RV-7
Old 04-21-2018, 07:04 PM
868RM 868RM is offline
Default starter
Bill, I have a new Skytec starter like you have on the shelf if it helps you get flying sooner. I am in Lena il. Not too far away. Ron 815 291 8864
