Finding an oily bottom spark plug is not necessarily a problem, but oily top and bottom plugs typically indicate that excessive oil is leaking past the rings.
If there are no signs of ring damage, the compressions are within spec, and the oil usage is within the manufacturer?s spec, I would be hesitant to recommend pulling a cylinder based on oil consumption alone
I had an O320 160 hp powered 4 for 4 years and 450 hrs. The oil consumption was 1 qt every 12-15 hrs. After about 15 hrs it would start to run rough during the runup. Usually the #4 bottom plug but occasionally a different bottom plug was fouled. Often the #4 plug was a little oily. Cpmpressions were all in the mid 70's. I put 37BY's in the bottom and went from 15 to 100 hr cleanings with no issues. Always leaned in cruise and on the ground. Still running the same today with a new owner. FWIW.
Al
