Old 04-20-2018, 12:09 PM
JBHansen JBHansen is offline
Default Control Tunnel Cleaning
Does anyone know of a device, like a spray and vacumm together, to clean down in those crowed control tunnels? Think very small carpet cleaner. I just can't get in there with a rag.
Old 04-21-2018, 07:01 AM
titanhank's Avatar
titanhank titanhank is offline
I have an air compressor powered vacuum with a 12" hose on the end. Works great.
http://m.aircraftspruce.com/catalog/...?clickkey=3761
Rv-6
0-320/180+hp
10-1 pistons
Lycon port/polish
Dual pmags
EI Commander
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod/cable locking
Electric seat back adjuster
Old 04-22-2018, 07:13 AM
rwarre rwarre is offline
Default Plastic straw
I hold a plastic straw placed into the end of a vacuum. Works pretty good as long as you hold on tight to the straw.
Old 04-23-2018, 08:57 AM
Default Thanks
Thanks for the suggestions. I will give the aircraft spruce vacumm a try.
