Old 03-11-2007, 09:21 PM
idleup idleup is offline
Default Question on Canopy Hinge Release Pins...
My manual and the plans show the pins as part number AN43B-16 but the only thing I got that is close to that (checking the packing sheet to confirm it is the only thing I got) is AN43B-15A. The difference between the two seems to be that the ones I got have threads on them. Anyone else experienced this?
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 03-12-2007, 06:58 AM
terrykohler terrykohler is offline
Matt:
If you're going with a removable canopy, you'll need to check the length required for the retractable pins, remove the threaded portion, and chamfer/radius the ends. If you don't intend to install the bellcrank (I'd recommend you do, but mount the mechanism vertically on the subpanel), then use the pins or shoulder bolts along with washers and locknuts.
Old 03-13-2007, 08:16 AM
So it is a known issue that the plans and drawings are referencing an incorrect part number?
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 03-13-2007, 08:42 AM
dan's Avatar
dan dan is offline
No, you just need to modify what they give you -- per plans.
Dan Checkoway RV-7
Old 03-13-2007, 02:41 PM
Maybe I was unclear. DWG 47 references the canopy hinge pin as part number AN43B-16. There is no AN43B-16 on the packing list or kit contents. There is however a part AN43B-15A which is included, but not referenced anywhere within the plans.
My original question was if anyone else has encountered this discrepency.
Dan, I do not understand your comment...There is nothing in the plans stating to modify the AN3B-15A to create a AN43B-16...
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
