Go Back   VAF Forums > Model Specific > RV-14
  #21
Old 04-20-2018, 07:49 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by iamtheari View Post
The GTX 45R manual doesn?t seem to specify a maximum cable length, so I should be okay to use the rear location.
Hello iamtheari,
Sorry that the new GTX 35R/45R manual doesn't specify the maximum cable length. We will need to get that added.
The GTX 345 manual does specify the maximum loss between the transponder and antenna to be 2.0 dB.
RG 400 coax is ~0.185 dB per ft loss
BNC connectors are ~0.2 dB each (0.4 dB total)
The maximum length of the RG 400 cable should be (2.0 - 0.4 dB)/0.185 dB/ft or 8.6 ft. The minimum length is 3 ft.
We installed the GTX 45R in the tail of our RV-7A with the minimum length cable to the bottom mounted antenna nearby.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 04-20-2018, 08:51 AM
Raymo's Avatar
Raymo Raymo is offline
But the useless holes in the fuselage will bug me.
I used these to plug fuel tank vent tube holes in the fwd lower fuselage on my -7A and the un-used pitot static hole in the left wing.
You can pick them up at one of the big box home improvement stores. None have come out in over a year.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 04-20-2018, 09:32 AM
iamtheari iamtheari is offline
Originally Posted by g3xpert View Post
Hello iamtheari,
Steve
Steve: Thank you. I don't suppose you have any cool tips for how to use the holes I drilled in the skin or the 15-foot coax running back to the tail.
Old 04-20-2018, 09:14 PM
I decided to pull the coax out (11 oz of weight in the tail) and order a replacement tail skin. $24 vs my OCD, OCD won. I also ordered the flap position kit and double sided tape so I don?t have to use pro seal on the elevator trailing edges if I don?t feel like it. (Although the rudder turned out nearly perfect using pro seal and results are all that matter.)
Old 04-21-2018, 07:00 AM
mountainride mountainride is offline
It has been driving me crazy as well...
I think I am going to fabricate both a flat piece of aluminum with nutplates that can be screwed in to completely cover the hole, and a second piece that has a gopro mount protruding through the 1/2 inch hole I drilled in my airplane. That way I can either run with the cover or have a camera with a great view.
This means dimpling the two #12 holes for screws (using a pop rivet die?)
RV-14 N303XC : Flying
Old 04-21-2018, 03:17 PM
JDA_BTR JDA_BTR is offline
It is a pretty nice drain hole back there huh? Wouldn't be a bad option for a VOR antenna in a trigear except for the drag. Not sure which one is plug/play there.
I was going to see how it went with my 45R with the transponder antenna in the tail but now I guess not....
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 04-22-2018, 03:02 PM
penguin penguin is offline
Archer internal VOR wingtip antenna is the only option! Installed per the instructions it works very well. Cats whiskers are ugly and draggy!
Pete
Old 04-23-2018, 07:25 AM
Pete
Which model of Archer antenna did you use? I see they have a few different styles and I can't tell the difference from a distance.
