Old 04-12-2018, 05:02 AM
blueflyer's Avatar
blueflyer blueflyer is offline
Default What Material are Lycoming Cylinder Studs Made of?
Does anyone know what material the Lycoming Cylinder studs made out of? Are they carbon steel?
Old 04-12-2018, 11:32 AM
lr172 lr172 is offline
I do not know, but assume they are a carbon steel alloy that would resemble the elemental makeup of a common Grade 5 bolt.
Old 04-12-2018, 03:42 PM
blueflyer's Avatar
That's about what I thought too. Thanks for the input.
Old 04-12-2018, 08:51 PM
AlexPeterson's Avatar
All steel has carbon - I'm curious why you asked?
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 04-13-2018, 05:42 AM
blueflyer's Avatar
I am doing research into cylinder studs because I am having to replace a couple. In researching which studs are right for my engine, I began to wonder about what they were made of, and I didn't see that in any documentation I found.
Old 04-13-2018, 05:50 AM
BillL BillL is offline
If you really want to know you will have to burrow down in the certification documentation. It has everything there. I would be surprised if the spec is near a grade 5 though. just due to the required infinite fatigue life. Engine structural fasteners can evolve to be quite unique depending on failure history. Particularly, main, head, connecting rod etc.
Bill
RV-7
Lord Kelvin:
