04-11-2018, 01:13 PM
Has anyone every built a hangar?
Starting to do research on metal hangars and wanted to know if anyone has some experience? Which are good/bad quality?
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
04-11-2018, 01:42 PM
I've built 2. First one was from Tyler Building Systems in Tyler Texas (1990).
2nd was from Red Dot Building Systems in Athens Texas (2003).
Both were very good products and everything fit as it was supposed to.
All steel buildings with insulation.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
04-11-2018, 01:56 PM
D,
Built, or wrote a check?
04-11-2018, 01:59 PM
Senior Curmudgeon
Yep, one steel and one wood hangar.
You might contact Rapidset metal buildings https://www.rapidsetbuildings.com/
They advertise here, and the owner is building an RV.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
04-11-2018, 02:15 PM
Originally Posted by rv7charlie
D,
In my case....Built!
04-11-2018, 02:29 PM
The reason I asked is that he won't get useful info without responders knowing whether he wants a kit that he'll assemble, a turn-key building for which he writes a check, something in-between, or even a source for the materials.
Most of the hangars on my home airpark were erected by a company that built 'chicken houses'. Might sound less than ideal, but they were much less expensive than typical metal building companies charged at the time, and a metal building is trusses, purlins, and skin.
And if he's into DIY, he could really save money. I added a 30x50 'lean-to' on my hangar using 4x4 supports, 30' metal purlins, decking, and regular metal roofing, doing all the work myself.
Charlie
04-11-2018, 03:37 PM
I built a 60X70 Kentucky Steel Truss building. I'd buy again.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
04-11-2018, 04:19 PM
Built 50x40 whirlwind steel building in april 2017 with 50x40 ramp, schweiss 40x12 bifold door, fully insulated, turnkey and ready to put the plane in for $75000. The lot, which i own, and the fuel farm pushed it to $90000 total as it sits today after wiring, lights, overhead fans and plumbing.
Figure $40/ft will give you a real good completed cost minus the land.
Rv-6
0-320/180+hp
10-1 pistons
Lycon port/polish
Dual pmags
EI Commander
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod/cable locking
Electric seat back adjuster
04-12-2018, 06:19 AM
I saved 35% off of a kit price and just ordered the materials from Mueller's in Texas and built my hanger/shop/living quarters myself. I copied a friends basic design and made modifications to suit my needs. Mueller's salesman helped me with engineering. It was a sizeable task but easier than building an airplane!
04-12-2018, 06:42 AM
Ya know, in our part of the country (same as yours basically) the Amish are famous for building pretty darn good pole barns for very reasonable prices. Corrugated metal roof metal sides same as an all metal building. Neighbor on our 7MD1 property had them put up a 40x40 with concrete floor (I cant rem but 3k psi comes to mine, maybe 3.5....) and I rem him saying it cost him 25k. He did the hangar door himself, a hanging slider. I'll do the same when the time comes. Just a thought.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
