04-10-2018, 04:50 PM
Dynon D6 doesn't detect Remote Compass
Anyone have this issue and find solution.
I'm merely connecting a Dynon D6 to the remote compass. But the D6 gives an error message saying "Remote Compass Not Detected." I have checked and double checked the 4 wire connection. Cable is about 20 feet long. Remote compass is tilted down about 7 degrees to match the tilt of the D6 in the panel.
Ideas?
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
04-10-2018, 05:15 PM
Someone else reported a similar problem here. Turned out to be a ?weak? (malfunctioning) RS-232 module.
I don?t think you want to tip the magnetic sensor. Check with Dynon.
04-10-2018, 05:52 PM
If that's the case - a weak RS-232 module - then try a temporary test with a much shorter cable.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
04-11-2018, 08:58 AM
RS 232
On this same panel, the Garmin 430 is say, "not receiving data on RS232 channal1. Is this related?
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
04-11-2018, 09:18 AM
Are the Dynon and Garmin RS232 cables reversed?
Joe Gores
RV-12 Flying
04-11-2018, 09:55 AM
Or, said in another way...
Does the TX from one end go to the RX at the other end.
Gil Alexander
04-11-2018, 09:32 PM
D6 still doesn't recognize compass
I tried swapping the data wires for the Tx vs RX issue, but no difference.
I measured 16.8 Volts going into the compass on pin 6 from the D6.
I verified the ground is ground.
Any other ideas? Is there a reset on the D6? When it starts it doesn't look like it makes any attempt to detect an attached compass. It just pops up with error message.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
04-11-2018, 10:01 PM
Is there a calibration procedure? I recall for my GRT going around a compass rose.
04-11-2018, 11:51 PM
Just a thought, any chance you are using an older magnetometer from an early D10 efis?
The 9 pin connectors on later D10A / D6 (current) magnetometers are wired differently.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
04-12-2018, 11:52 AM
Sending it to Dynon
Dynon called, I'm sending the two units to them to fix.
It does have a calibration setup done later with a compass rose, but that's after the D6 and compass are talking to each other.
UPDATE: April 24, 2018 Dynon fixed the D6 and Remote Compass and sent them back. There were internal issues. Everything works fine now.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
