Old 04-09-2018, 08:07 PM
Driving '67 Driving '67 is offline
Default Rudder pedal Bearing Block
I?ve been working on the installation of my rudder pedals and the top portion of the bearing block appears to be too thick to fit between support angle and the rudder bar. It looks I?m going to have remove about .075? of material to fit without binding. Has anyone else bumped into this? To date everything has fit perfectly so I?m wondering if I?m missing something. Both ends of the rudder pedal blocks went into their respective holes with no issues or binding.
RV 14A
Flying!!!!
Serial 140118
Donation - 2022 gladly done!
Old 04-09-2018, 08:29 PM
mturnerb mturnerb is offline
I had to make a similar adjustment. Bungled it the first time, re-ordered.
Turner Billingsley
RV-14A built/sold N14VB
Old 04-09-2018, 09:10 PM
JHartline JHartline is offline
Adjusted mine too. Don?t forget the washers in between the blocks.
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
Old 04-09-2018, 09:24 PM
Thank you Gentlemen .... much appreciated.
RV 14A
Flying!!!!
Serial 140118
Old 04-11-2018, 10:23 AM
rapid_ascent rapid_ascent is offline
I think this falls into one of those build order issues. Sometimes it appears the instructions don't always call out the best build order. I haven't looked at the 14 instructions so I'll throw out that disclaimer too. I think on mine I marked the hole locations on the firewall stiffener, bolted the bracket to the rudder pedal assembly, aligned the bracket holes as best I could to my marks, clamped the bracket to the firewall stiffener and match drilled.
Ray Tonks
2022 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 04-11-2018, 01:54 PM
salto salto is offline
In a practical sense a bit of resistance there is not an issue.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 04-11-2018, 09:46 PM
The bearing block bolt holes match up to the support angle perfectly. The block is just too thick and if forced will probably cause the firewall to bulge. As the other posters mentioned they had to remove material prior to final fitting. As a first time builder I?ve got used how refined the RV14 kit is.
RV 14A
Flying!!!!
Serial 140118
