Hello Gents
A friend is installing a Garmin 327 txpr in his airplane and would like to confirm that he did wired it properly before powering the unit.
For the ones of you who installed one, could you confirm his Pin out so that he doesn't blow up anything.
He's using PIN 2-8-15-20-25 ...He 's wondering if he needs to use Pin 1 to turn the unit on with the Avionic Master Switch??
He is using the encoder of his EFIS (Skyview )and wants the Txpr to be displayed on the EFIS.
He's got the same setting I have so it should work...
This will allow me to crosschecked mine also..
Thank you for your imputs..
Bruno
