Go Back   VAF Forums > Avionics / Interiors / Fiberglass > COMM
  #21
Old 09-16-2018, 11:34 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
BNC to BNC should be fine. I would not however mount an ADS-B in antenna over the bent part as it is easy to find better spots.
90% of the bent whip energy is radiated in the first third of the antenna (the more vertical part).
Carl
Old 06-11-2020, 07:18 PM
FinnFlyer FinnFlyer is online now
Originally Posted by az_gila View Post
Yes, running four #22 wires vs. RG-400 co-ax is a no brainer. My -6A has about a 6 inch section of co-ax for the Dynon ADSB box and my -10 will be similar.
In both cases the boxes are aft of the baggage bulkhead.
Looks like I'll have to mount the echoUAT antenna about 10' aft of the firewall (I moved the GTX320A antenna about 7' aft of firewall to keep distance to 5.5' long muffler/exhaust pipe).
But if mounting the echoUAT unit in the aft fuselage, will the WiFi signal reach the cockpit (Nexus 7 tablet running iFly GPS and for configuration of the echoUAT.) ?
Finn
N214FL RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
