Old 03-10-2007, 10:59 AM
MTBehnke MTBehnke is offline
Default F-904G vertical bar rivets
Squeezed the AN426AD4-14 rivets that attach the vertical bar to the spar carrythough web. The heads of my rivet ended up closer to AD3 size, both in diameter and height. It would appear these two rivets simply hold the bar in place until the spar is bolted into place. Has anyone else experienced this? Should I be trying to find a source for -15/16 rivets and replace these?
Mike Behnke
RV-9A - sold
Old 03-10-2007, 11:27 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
I had the same problem and reached the same conclusion. I left them as-is. Drilling those out will not be easy, anyway!
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 03-10-2007, 11:50 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
This topic has come up in the forums before. The only purpose for these rivets is to hold the bars in place until you get the bolts through the center section and wing spars. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-11-2007, 10:00 AM
Thanks Paul and Steve - that's what I thought - and was hoping for. I searched all over the site, but couldn't find a previous post on this so thanks for your help!
Mike Behnke
RV-9A - sold
