04-05-2018, 03:26 PM
A Nutty question
I have absolutely no info on the proper nuts to attach my carburetor to my O-360. Elastic stop, all metal stop, drilled hex with safety wire, lock washers. I know this sounds like a dumb question but if there was anything I want properly installed to keep tight it?s the carb.
Thinking about vibration and heat. Received new engine with the Carb in its box and no nuts on the mounting studs.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
04-05-2018, 03:41 PM
Thick or thin washer, internal star lock washer, followed with a plain nut. (All aircraft quality of course.) If the part practically NEVER gets removed, I will leave the flat washer off, but that is my idiosyncrasy. If you really want to be anal, a small dab of blue lock-tight wouldn't hurt.
04-05-2018, 04:02 PM
Thank you dwrichie. If this were my tractor that?s exactly what I would do. Who?d a thought it would be the same for a aircraft. On this plane I question every move I make cause on a plane, it?s just ain't the same. This has been holding me up a little so I really do appreciate your help.
Tom Norwood
TMX-O360. Phase 1
04-05-2018, 05:54 PM
I had the same question regarding the throttle body attachment to my IO-540 on my RV-10. Found the answer in the Lycoming Parts Catalog document PC-215-1A, which is available on Lycoming's website.
For the IO-540, on pages 6-7 and 6-8 Lycoming specs:
WASHER, 5/16 plain
NUT, 5/16-18 plain
LOCKNUT, 5/16 palnut
Not sure if this is the same for the O-360, but you might want to check Lycoming's parts catalog document for your engine.
Dave Macdonald
RV-10 First Flight April 1, 2020.  Currently in Phase 1
2020 VAF Dues Paid
04-05-2018, 07:32 PM
O-360 Parts Catalog
04-05-2018, 08:27 PM
Well....
The Lycoming is similar to either an old tractor motor or a ditch pump, so you should be fine using the same methodology
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
04-05-2018, 08:44 PM
As the manual mentions you can use the washer, lockwasher and nut. Vic Syracuse states he has seen more than one come loose so he uses AN363 all metal stop nuts with a washer. I followed in his suggestion.
More on his take on this thread http://www.vansairforce.com/communit...d.php?t=148894
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
04-06-2018, 03:32 AM
all metal lock nut 1/4-20?
Hi,
Has anyone been able to find something like an AN363 1/4-20? I can only find -28. Currently using star lock washers, but would prefer a real lock nut if I can find it. There are several places on the engine where the stud is 1/4-20.
Mickey
04-06-2018, 06:37 AM
Originally Posted by rv8ch
Hi,
Mickey
AN363-420 at B&B Aircraft or Wicks.
Carlos in Arizona
04-06-2018, 07:29 AM
Thanks!
Thanks! B&B website didn't work, ordered just now from Wicks.
