04-05-2018, 11:23 AM
I have three EAA 1000-type benches, two 2x6 and one 2x4 (eg all from one 4x8 sheet). I also modified the plans to make the benches a bit taller since I'm a tall guy.
The 2x4 is my power tool bench, with a bench grinder, drill press, and band saw mounted. The other two have the "retractable gear" mod for semi-easy repositioning as needed. One of the 4x6s also has my bench vice mounted on one end. That's about as far as I went towards making my benches non-generic in any way.
For C-frame dimpling, I built a frame out of 2x3s (I think that's what I used), with three cutouts where the C-frame can be placed, and carpet covering the rest. I just clamp this onto a work bench when doing dimpling. Said frame thing can be seen here: http://rv.squawk1200.net/2014/07/09/...frame-fixture/ and also here: http://rv.squawk1200.net/2014/09/02/skins-dimpled/
In retrospect, the three cutouts were overkill, I don't think I've ever used anything but the center one. Meanwhile, having some space in front of the dimple die would have been useful; sometimes I've had to get creative holding skins when dimpling an edge. But it's been perfectly serviceable.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
04-05-2018, 11:26 AM
If you are going to be pounding a C-Frame dimpler on your bench, add extra legs right under the C-Frame location to stop bouncing and make your whacks more effective.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
04-05-2018, 11:55 AM
Don't put your C-frame cutout in the middle -- put in two of 'em, each 1/3 of the way in. Gives you more flexibility for doing long part. Also, an R2D2 (whatever the correct part number is) squeezing dimpler is well worth the money, so much nicer than pounding on a rivet set with a C frame.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
04-05-2018, 01:03 PM
I built two of the standard EAA workbenches with the 2 in overhang all around as the only modification. I carpeted both of them with some commercial carpet about 1/4 in. thick. I have a back bucking plate that's 4 in. X 16 in. X 1/4 in. thick. I carved out a couple of sections out of the carpet using the plate as a template so I can drop it in when I need it. When I'm don't need it I put the carpet section back in place. Works great.
I also got a set of wheels (4) that are retractable. I installed two of them on one end of each table so I can move them like a wheelbarrow. They just kick into place when I need them. You can find them here.
I also built a movable power tools bench with my bench grinder, belt sander, drill press and band saw. It saves a lot of space and give you flexibility to move things around as needed. I'm very space challenged in my garage and this helps a lot.
I have details in my construction log if you're interested. The link is in my signature below.
Originally Posted by Ed_Wischmeyer
... Also, an R2D2 (whatever the correct part number is) squeezing dimpler is well worth the money, so much nicer than pounding on a rivet set with a C frame.
+1
I might also add that the DRDT-2 makes it much easier to work solo when dimpling. You can use one hand on the part and one hand on the DRDT-2 handle. With a C-frame I had to use both hands on the frame. The DRDT-2 is simply more controllable.
There are some who claim the DRDT-2 doesn't produce as good a dimple as the C-frame. I believe those people didn't properly set up the device and that's why their dimples weren't as good. Take the time to get it set up right and your dimples will be as good or better than a C-frame. My dimples are perfect every time.
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Reason: Added DRDT-2 comments
10-30-2018, 03:45 AM
I agree
Originally Posted by ppilotmike
I wouldn't mount anything to your benches. I built 3 tables and originally thought I would mount my grinder, sander, band saw and drill press to one, creating a movable "machining area." However, what I've determined, over the course of my build so far, is that it's far better to be able to move things around and set them up as needed. People that incorporate dimplers, back-riveting plates and other things into their tables quickly find that there is some compromise that's made because of how they mount those items. Keep things movable, is my advice.
Now, that doesn't mean you shouldn't think about how you're going to clamp things in place in order to use them. For instance, my DRDT2 dimpler clamps beautifully across my table, with a clamp on each side. I have a mat that I use with the back-riveting plate that's just the right thickness, so the material slides right across the plate. I have cross clamps that I use to secure items vertically across my tables. Also, my tables are able to be used in conjunction with each other (i.e. they can be set up side to side, or lengthwise with each other to turn into larger work surfaces.)
Even at an early stage in my build I agree with Mike on this. I built one long "assembly bench" and use another older bench for tools - grinders, vices, hand-shears, drill press. This way I can get to a tool when I need, but also have a big flat space to put bits together. My bench was made using modular storage racking stuff (not the EAA timber type), so if I wanted I could add length easily.
RV-9, Tail Feathers done, Wings almost done.
10-30-2018, 04:24 AM
EAA benches with modifications
I have several EAA type benches with the following modifications;
Replace the top plywood with 2 X 6 slats spaced like deck boards for weight and stability. Overhang for clamping ease.
Add a sheet (cut to size) of 1/2 inch ply, MDF or OSB as a sacrificial layer.
Cheep outdoor carpet for scratch suppression.
Cut legs to an overall height that is comfortable (36 inches typical)
The 2 X 6s add weight and strength, the 1/2 inch stock add a throw away surface for the thousands of dings, drill holes etc., and the carpet … well.
For dimpling I have two 'mini tables' I set on the bench to either side of the dimple frame and move around depending on the size and shape of the piece I am working on to hold the piece level. I just lay my back riveting plate on the bench to use. I also have a dedicated 'dirty' bench for all grinding and cutting machines, but that is another discussion.
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
