  #41
Old 05-10-2018, 05:53 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
This struck me as odd, not being able to give a BFR in your plane.
I recently sent for a copy of a LODA for someone I knew, and found NO REFERENCE whatever to a BFR requirement nor any prohibition against giving a BFR. Is this normal practice, or does it just strike each FSDO differently each day of the week?
[quote=TimO;1250391]I have a LODA (authorization from the FAA) to do transition training in the RV-14. Last year I went thru the process. I'm sure that there is at least a SMALL chance that some people would have different results than I did, but, in my case doing a Flight Review in the RV-14 not all all do-able.
As part of my authorization I cannot even give transition training unless the pilot ALREADY has a current "BFR".
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 05-10-2018, 08:17 PM
[quote=DonFromTX;1259135]This struck me as odd, not being able to give a BFR in your plane.
The FAA?s position is quite clear: an EAB airplane may not be used for compensation. They will issue a waiver (LODA) specifically for transition training only because it cannot realistically be done in anything other than an RV. Every LODA I?ve seen says ?transition training only?. Now there is the question, ?If during transition training we satisfactorly accomplish all the elements of a Flight Review, may I (as a cfi) endorse the pilot?s logbook as Flight Review given?? My LODA says ?no?. This strikes me as unusually strict. But I guess if it was otherwise, people would cheat - e.g., ask for/offer transition training when all they really wanted was a Flight Review. Just to be clear, a LODA is needed for the EAB to be used for compensation. You may get and pay for a Flight Review in your EAB, the presumption being that you don?t rent the plane from yourself.
Old 05-10-2018, 08:31 PM
DonFromTX's Avatar
Interesting. To make a discussion, the words "for transition training only" certainly does not infer to me that you could not use your plane for pleasure or sightseeing or personal travel - or giving a flight review. The one I received however had the statement that the plane can make "No demonstration flights are allowed". I am not even sure what a "demonstration flight" consists of.
[quote=BobTurner;1259165]
Old 05-10-2018, 08:46 PM
The waiver (LODA) is for using the airplane for compensation. You don?t need the waiver if no compensation is involved, like personal travel. No waiver is needed if you get a Flight Review for free. But a CFI cannot furnish his airplane ?for free? and charge for his services - the airplane is clearly tied to him being compensated.
Old 05-11-2018, 06:38 AM
flyinhood flyinhood is offline
Thank you to everyone in advance. I am new here and just bought my first RV last week.
I am an active CFI with no LODA (yet...maybe)
Can I offer flight training with me, and my plane, if no money changes hands?
ie: a young person spending time with me to suppliment their private, a few approaches with a friend to get current, etc.
Or...does anyone know if, because a Comm is required to have a CFI, that ALL training is considered "commercial" regardless of money changing hands?
Thx,
Hoody
46 Luscombe 8a Rag Wing, Armstrong starter
RV-6, IO-320, Catto, G3X Panel (Thanks Walt!)
Old 05-11-2018, 06:52 AM
Jesse's Avatar
Jesse Jesse is offline
Thx,
Hoody
As long as you pay your pro rata share of the expenses, you are not flying for hire, so you can do it.
Jesse Saint
Old 05-11-2018, 07:15 AM
Vern's Avatar
Vern Vern is offline
Question Airshow performer use of EAB aircraft
I've always wondered at the regs that will not allow the needed training in EAB but allow some airshow pilots to make a living using their EAB aircraft.
Anyone got any ideas?
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 05-11-2018, 07:47 AM
Auburntsts's Avatar
The FAA’s position is quite clear: an EAB airplane may not be used for compensation.
I get the primary training vs transition training and LODA stuff. However, I'm not sold on the total no compensation bit outside of the training issues.
Can someone point me to where it says you can't be compensated for performing other, non-training tasks with an E-AB aircraft?
I get 91.319 states:
(a) No person may operate an aircraft that has an experimental certificate—
(1) For other than the purpose for which the certificate was issued; or
(2) Carrying persons or property for compensation or hire.
And my OPLIMS, issued under the older FAA order 8130.2G (current version is 2J IIRC) has the same verbiage as 91.319 (a) (2). I'm also prohibited by my OPLIMS from glider towing, banner towing, or intentional parachute jumping.
But what about skywriting or aerial photography? Why couldn't a pilot flying their own E-AB be compensated (ie paid) for those activities? There's no carriage of persons or property.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 05-11-2018, 08:41 AM
rvbuilder2002's Avatar
(a) No person may operate an aircraft that has an experimental certificate?
When reading a document in the context of "legal" meaning, single specific words can mean a lot (even if the person reading it doesn't understand the relevance).
In that context, ask your self why does it say compensation and hire? Wouldn't just one suffice?
Apparently not.
So now you need to find out what the FAA means by those two terms.
Unfortunately, in this case, the writer (FAA legal dept) gets to define the terms, not the person reading them. The FAA has been very clear in the past regarding what their definition is.
Scott McDaniels
Hubbard, Oregon
Old 05-11-2018, 09:03 AM
Auburntsts's Avatar
Apparently not.
Umm, because they don't mean the same thing? In any event, the way the paragraph is worded to me implies that the compensation and hire prohibition applies to the carriage, and only the carriage, of persons or property. Otherwise if you wanted to prohibit all activities for compensation or hire why not just leave "persons" and "property" out altogether? But they didn't so they made the prohibited activities specific and not general.
I also have no plan to ask the FAA anything. I simply want to know is there a reference that applies the compensation prohibition beyond what's stated in 91.319 such as a reg or FAA General Counsel ruling and not for anyone to try an provide an interpretation of 91.319, legal or not.
NOTE: This if for my edification only -- I have absolutely no desire or need to fly for compensation in any aircraft, regardless of its certification.
PP ASEL-IA
WAR EAGLE!
