  #11
Old 07-24-2019, 01:49 PM
We prototyped one in a RV7 mounted under the Andair valve. Used with the AFP boost pump under the STOCK covers. Was a tight fit, especially near the spar for the valve to gascolator inlet tube. The install works---client wanted it under the stock covers.
WE may play with this more if Blake gets a bunch of interest.
Tom
Ridgeland, SC
Old 07-24-2019, 03:47 PM
Richard Connell Richard Connell is offline
Originally Posted by digidocs View Post
FWIW... I've measured the floor of the tunnel where the gascolator would attach at around 160F if I remember correctly. This heat could potentially take an Aerolab setup closer to vapor lock than the conventional filter.
Sorry I should have been more specific. They are installed outboard tucked under the gear weldments. This avoids the heat problems as well as the center bottom fuselage on the outside being a messy area.
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
