03-28-2018, 01:02 PM
2 x 14awg's to 14awg
Hooking up my Garmin regulated heated pitot today .. I need to get 2 14awg wires connected to a single 14awg. The heater has two inputs. It has to be a connector as it needs to be easily removable. Any suggestions on what type of connector would work well here? Thanks for any help!
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
03-28-2018, 01:15 PM
I'd probably work up a 2 pin Molex using a jumper either crimped into the pin together with the power line, or spliced and soldiered just slightly upstream if the connector wasn't big enough.
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
03-28-2018, 01:45 PM
I like the knife connectors for this type of work. Heat shrink over them after connecting.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
03-29-2018, 04:28 AM
16g or 14g, your title says one and body says another. May make a difference, also, what current draw are you looking at ?
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
03-29-2018, 06:37 AM
I didn't know knife connectors could be used for joining three wires together. Can you please share how that's done?
Kurt W.
RV9A
FLYING!!!
03-29-2018, 06:57 AM
16awg .. couldn't edit the title ..
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
03-29-2018, 08:39 AM
Terminal block
I did a retrofit of the Garmin heated pitot. I ran the 2 wires from the pitot to a terminal block mounted under the seat pans in my 7A.
I then put a jumper between the two 16's and ran a single wire to the pitot heat breaker.
FYI. The terminal block was already mounted. I use it to run the wiring to the wings. I guess a lot of people are using Molex connectors these days but I still like terminal blocks.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
03-29-2018, 08:54 AM
I generally use butt splices on everything I can, much more reliable than a connector and easy to cut out and re-splice (if you leave some slack) in the event it needs to be disconnected (pitot probes are not failure prone).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
03-29-2018, 09:19 AM
The knife connectors are interchangeable regardless of size (red, blue, yellow). You could, in this case, use a yellow for two 14 g wires and a blue for the other side.
Ray
03-29-2018, 09:28 AM
This is a cool idea, thanks! It had never even crossed my mind to try and connect two different colored knife terminals together...
Kurt W.
RV9A
FLYING!!!
