  #21
Old 03-27-2018, 01:49 PM
BruceW BruceW is offline
As already mentioned, if you make openings in a structural skin, you should at least be using AC 43.13 as a guide for maintaining the the same strength as what the uninterrupted skin had.
This would be a lot easier to do by using the same materials vs switching to fiberglass laminate.
THIS !
So glad I added two access panels on my RV-7. Even on a tip up, it saves SO MANY panel dives. Plus, it's a good 'skin patch' practice for A&P training later on.
Bruce W
RV-7 QB
(500+ hours)
Elk Grove, CA
Old 03-28-2018, 07:48 PM
F1R F1R is offline
With most of the large format EFIS displays, you have a built in quick access that is faster to get open than 24 screw heads. Perhaps even a larger opening also.
Old 03-28-2018, 08:36 PM
rv7charlie rv7charlie is offline
Suggest rereading posts and reasons by those who have done it.
Old 03-28-2018, 09:19 PM
wjb's Avatar
wjb wjb is offline
This is what I did for access: built a pallet that sits under the skin between teh FW and subpanel, and plopped most of the boxes on that. It's attached using piano hinges to the fore/aft ribs, and drops down easily for maintenance or removal
Bill Bencze
Old 03-28-2018, 09:31 PM
cajunwings cajunwings is offline
Default Access panels
Originally Posted by JDA_BTR View Post
What do you do to prevent water intrusion?
On the 2 planes that I have added acess panels there is an additional .032? aluminum spacer ring between the nutplate flange and the front deck skin. This extra stiffener allows for a .032? thick molded in place pro-seal ?gasket?. I made a jig and used a router with a spiral upcut bit. Cutout looked like it was done with a laser. Still have the jig and could duplicate on any 7 or 9 slider front deck skin.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
